Spark Plug Recommendations
(In Topic #210651)
4 prog plug so no worries about gapping the plugs, fit and leave then I replace mine every 20,000 miles.
You will need to unscrew the cap if you have later HT leads with "saw tooth" connections.
On sale at Euro car parts, use code SALE56. £13.85 for 4 plugs.
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf+Cabriolet_1.8_1988/p/car-parts/regular-service/car-service-parts/spark-plugs/?408330010&1&d474aada81a341b2b530705f536fb89d782adb5a&000301
Just found them cheaper here.
http://www.carparts4less.co.uk/cp4l/c/Volkswagen_Golf+Cabriolet_1.8_1989/p/car-parts/regular-service/car-service-parts/spark-plugs/?408330010&1&d474aada81a341b2b530705f536fb89d782adb5a&000301
£10.24 for 4 plugs with "PAYDAY12" discount code.
mark1gls said
Bosch plugs in both my cars and I've been using them for 10 years + with not problems (I've have changed them in the 10 years of using them :-) )
I had a bad Bosch Plat 3 plug. Bought 2 replacement sets, and each set had 1 and then the 2nd set of plug had 2 bad in the box of 4….. Made troubleshooting fun….
I use NGK BP6ET Digifant II 2h actually they are amazingly different and feel like I installed a Turbo on my cars…
www.cabby-info.com has a listing of the plugs for various VW numbers.
http://cabby-info.com/Files/SparkPlugs.pdf
TeeTee said
I've always used NGK but have just bought some Bosch. Seeing as everything else in the ignition system is Bosch it seemed to make sense. I'm interested to see if there's any difference.
Yep, there is……..
http://www.vwspares.co.uk
http://www.classic-vw.co.uk
I've recently tho just changed out all my stuff for Beru, and the car runs lovely.
Try a set and if you're not satisfied buy something else.
We not talking a large sum of money at the end of the day!
I have a '81 tintop 1.6 gti, engine code EG.
Which plugs please inc. code?
I'm having a misfire under load so gonna try replacing them first.
‘81 Golf GTi Mk1 TSR1600 tintop
'90s Chesil Speedster on '70 VW Beetle Chassis
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
There should be a code on your spark plugs fitted to the car.
https://www.eurocarparts.com/p/bosch-spark-plug-408330010
https://www.vwspares.co.uk/VW_Golf_Mk1_Electrical.php?model=1.6%20GTi
VW list N01781159 for EG spark plug
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
I wonder if a cooler plug (a 6 rather than 7) may be better as I've been researching and it seems hot plugs when running hot can causing misfires.
I think thats whats been happening to me, hence why i starting looking into possible causes: the car runs cold fine but after 1/2hr or so starts to misfire. I had it happen at the weekend after a 20 mile run so parked up for a couple of hours, had a drink to calm down and it did run better for a while but again when it got back up to temp starting to misfire .
So maybe a cooler plug such as BP6ET could help? For less than £20 worth a try i guess…
(Although confusing i hear NGKs order their plugs in reverse order to other manufacturers).
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
If my Daughter hadn't returned from work with my other cabby where I swapped cap and wires from one to the other, I would probably still be working on it to this day
I used to use only Champion Plugs after Champion rebuilt the Engine in my 72 rover 3500S. (total rebuild). Because the ceramic part was badly crimped and injected in to my engine. The second set that I got did the same thing on the other side.
But after getting a set of bosch triple plats to run for 75000 miles I switched to Bosch triple plats, until I got buggered. NGK and my Cabbies seemed to get 10 HP more… or at least my SOP told me so.
It looks as though with NGK the lower number is hotter, with Champion and Bosch it's colder, brilliant.
I’m guessing I’d want for example a BP7EIX rather than a BPR7EIX. I think R stands for resistor and seems to be for motorbikes?
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
