Smoke coming from the heater motor!
(In Topic #215671)
Got a H reg Cab, tucked her away for winter decided to take her out today to keep the battery changered.
On start clearly something wrong either with fueling or spark as only running on a couple of cylinders - missing a lot a and foot down and going no where really.
THEN noticed smoke coming into the cabin through the vents, popped the bonnet and smoke coming out the hole where the heater motor is. I can't see if it's coming from the motor or somewhere under it.
A. Do these go? Easy to change?
B. If it's not that what's under it that could be smoking?
C. I can't see this being related to the running issue?
I did have the heater on for a moment but even when off as I limped it Home it started smoking again?
Any ideas?
Thanks!
ac or no ac.
year would be nice to know.
sweet smelling or acrid as in electrical.
Why?
Sweet smelling is a bad heater core.
Acrid is bad motor or wiring.
Saulty thanks for this, really helpful. He's cleared quite a lot from the engine bay as it had a front end respray last year and there's nothing really around it so might help when trying to take it out. Smoke was coming from the hole it's mounted in as I thought it might be that resistor at first.
My squeaky bum moment made me not look as hard as I should have.
Remove the cover and see if you can see wear it is smoking.
Dirty bearings cause the heater blowers to over draw current.
Wires on the side (passenger) of the heater box can brown and cause reduced current as well
Or his nuts….
Lol
Sent from my SM-G900F using Tapatalk
What's next?
Mk1 second project cabriolet
MK1 first project cabriolet
