Should my wheels have spigot rings?
(In Topic #233438)
i have an 87 GTI cabriolet that has tarantula 13 inch wheels
i know they were never fitted to the cabriolet from factory
should the have spigot rings? They are loose on the hubs, obviously the bolts line up
Thanks again
If its loose someones modified the hub or the wheel
Center Bore: 57.1 mm
PCD: 4x100
Wheel Fasteners: Lug bolts
I will take the wheels off and measure
all the drums and hubs are standard
as above centre bore should be 57.1mm when new, but id expect bigger due to refurbing and wear over the years.
On the drive
Myvalver 89 GTi Grey mk2 16v
Are both front and rear wheels lose as could be lose hub nuts as rears drums can go a little lose.
Stripped threads on rear drums or front hubs from tyre fitters using a buzz gun to put the wheels on?
Any rubble from bearings then quiet when cornering?
Post up a picture of the wheel bolts and hubs as my be able to spot something not right with your car or wheels as they should not have spigots.
Everything is 57.1. If they're vw wheels they'll be 57.1.
Have they been machined, is there a step or enlarged all the way down?
I've spent years running odd sized bores with no spigots, on low powered cars of course.
I even used to double stack spacers and run spigotless wheels…. Bad advice I know, but in all my years I've never encountered a problem.
I'm even running without spigots on my 20vt at the moment. .. doesn't bother me a bit.
On the drive
