Resistor rating needed
(In Topic #215617)
Early 77 year model Golf. 4-Door
rubjonny Briano1234
Sent from my Smartphone 📱
Maybe they just binned it off?
The part number that you referenced is for a oil pressure switch, which I don't think that will work as a replacement.
Not having the part, I would suspect that it isn't a resistor, but from the looks it is a coil or heater circuit… Resistors don't normally look like that.
a coil or inductor makes sense as well as a heating unit…. I would suspect that since I see heavy Crimped connection that it carried a load of current.
Resistors never look like that when they go south… They usually burn up…. Coils (inductors) can look like that..and could explain why you have 0 resistance….
I have a early Bentley I will see what they might say of that part…. The early Bentley (vw) wiring diagrams are similar to the cloud show a circle with inputs on one side and outputs on the other….
part 2 Early Bentley shows a heating element for the automatic choke...but no specific pictures of this part.
Last edit: by Briano1234
I do believe the part number is correct, as it is stated as "resistor" on the drawings. The same part is also used on Audi 80's up until 1984. It's just that they didn't bother to write resistor value
I can't find that part number now, as it is NLA since 1999.
