Removing clips from rear brake line hose (to replace the hose)
(In Topic #221604)
My brother is working on an Mk1 Golf Cabrio (Rabbit) in the States, and had a question we were hoping you could help with. He needs to replace the rear brake lines, but isn't sure how to remove what I believe are retaining clips (see photos below).
Does anyone have any advice on how to remove these to replace the hose?
Thanks!
Tony
There is every chance that attempt to remove the hose will result in the copper line shearing as the threads will be seized together.
If this happens you'll need to build new copper lines.
There is so little room to do the rears with the axle in place that its easier to just hacksaw through the line and cut off the hose as close to the end as possible and undo them with 2 small sockets imstead
Current rides:
