Relays
(In Topic #225601)
1989 Clipper carburettor
I'm a new member and this is my first post.
I'm trying to restart a project I started many years ago but abandoned for various reasons. I have a 1989 Clipper (cabriolet) 1.8 and has a carburettor rather than fuel injection. When I bought the car itwas running but it needed the cylinder head gasket replaced, which we did. The car would not start again. There was a strange buzz coming from the distributor so I replaced it but it made no difference, the new distributor buzzed the same as the old one.
Several years later I was told that while the head gasket was being done, someone messed about with the relays. I have looks at various pictures and manuals of fuse boxes but they seem to vary.
So my hope is that someone with the same model coul please share a picture of your fuse box showing the relays and hopefully I can get my project off the ground and back on the road.
Thanks in advance
I'll try and attach a picture of my own fuse box
Relay No. | Description |
1 | Open or Digifant relay |
2 | Fuel pump (fuel injection), Glow plugs (diesel), inlet heater (carb engine) |
3 | Seat belt warning |
4 | Shift light/MPG gauge relay (1985-1987) |
5 | A/C relay |
6 | Metal jumper for single horn or Relay for dual horns |
7 | Open or front fog lights |
8 | Load reduction/x-over relay |
9 | Open |
10 | Windscreen wiper |
11 | Rear wiper |
12 | Indicators, hazard switch |
13 | Open or electric windows |
14 | Cooling fan after-run (except 16-valve) |
15 | Passive restraint (1988, 1989) or ABS/coolant temperature relay |
16 | Idle speed boost control relay (k-jet 8v) |
17 | A/C thermofuse or ABS |
18 | Coolant warning light control relay |
19 | Electric window relay |
20 | Heated seats (left) |
21 | Heated seats (right) |
22 | Oxygen sensor system power supply (US cars w/CIS) / Automatic transmission relay |
23 | Electric window thermofuse (30A) |
24 | Glow plug fuse (Diesel-50A) |
Whip
/wip/
Noun - Car
/wip/
Noun - Car
(it has good pictures).
Dizzy's buzz if the cap isn't clipped on correctly….
I would check the firing order of the wires as well as the 0 Time . (static timing to make sure it is ready to fire…
Cabby-info in the ignition section has pictures of static timing in the menu drop down on the right.
Thanks again!!
