Refitting window guides
(In Topic #234397)
Anyone re-fitted these, and can recommend how they go back in? I’m resigned to the fact that they’re going to get scratched and will need re-painted once fitted - I just can’t figure out which way to fit them into the door without them snagging…
I opened the gap up between outer door skin and inner panel with a little bit of wood/doweling , and then it spring closed back up again when I removed the strip of wood.
Regional Host NE
then turn back when the tab is just
below the channel
adolf said
If it's the ones I'm thinking off - the black uprights ?
Thanks!
nicci21paul said
sure they go in turned 90 degrees
below the channel
Thanks! I did think of this but didn't think there would be room to rotate them at the bottom of the window opening
