Rear Fog Light Help
(In Topic #213085)
And found no power here either, I then checked the Fuse which seems to be fine but I replaced it anyway.
I've had a look on some other posts on here about the rear fog and see people saying that they're should be a relay in position 7 and by the looks of it I don't have one there? I also saw someone say trace the yellow/grey wire which I have found at the back of the Fuse box with a connector on but not attached to anything?
Can anyone help me out and point me in the right direction? Should I have a relay in position 7 and where does the yello/grey wire connect? And where do I go from here?
Cheers look forward to any. Replies
Rear Fog Light Help
headlights need to be on (main beam on just side lights) and ignition on position 2 (lights on dash) there is 2 positions on the fog light switch, 1st click is front fog lights (if ever fitted) and position 2 is the rear fog light.
Just in case it's a simple fix??
http://clubgti.com/showthread.php?219775
rubjonny said
that grey/yellow wire plug you have in your hand needs to go to M/1 on the rear of the fusebox:
Sorry to bring this up I have an 88 cabriolet should the yellow grey cable at the rear of the fusebox plug into M1 ? I only ask as after I've re wired lots of terrible wiring my rear fog light isn't working' I do know that I've connected it inline with the other yellow grey as they both have connectors on them
you only need the relay for cars with front fogs, for cars without you have it plugged into M/1. It works both ways just there is no need for a relay to power just the rear fog bulb, and without a relay the front H3 bulbs would end up a bit dim
Rear Fog Light Help
Confirm you have 12V at the switch output.
Pop the bezel off and pop the switch out.
Operate the switch to check that’s ok.
Once you’ve confirmed all’s good there.
You’ll need to cut the wire coming from the out put of the switch and solder and heat shrink sleeve a new wire all the way back to the loom in the boot.
I think it was the grey/yellow one.
Then unbolt the cheap nasty, after thought of a fog light hanging off the back of the car
Current rides:
okmate: M/2 isnt right as it will go dead when main beams are on, you need it on M/1 which is live both dip and main beam
1985: did this on my cabrio as the fog light in my box of bits was too far gone plus it looks garbage as you say. was looking at post-golf/s1 light which is red tinted on that side but they were always expensive for what they were
rubjonny said
chortle, dont forget the fuse inline with the rear fog wire
Sorry pal It was M1 Not sure why I said M2 I have these mental blocks now and again
Ideally the full reds are the best option but I've never found a set.
I had a box of spare with mine so I tried the red tinting spray, it's not brilliant but far better looking, ended up using a red led bulb so it was that much brighter than the brake lights
Current rides:
i have the grey/yellow wire on a relay but no power on this wire, there also a black connecter on the cable thats not going anywhere. gr Paul
the black wire with nowhere to go is your fog relay trigger, once you hook that up you'll most likely be back in business. what year is your car?
This gti from 1983 don't have front fog lights,
I need to try to putthegrey yellow with black connector on the 12v continiue?
Thanx
so for ce1 without front fogs you simply put the female grey/yellow spade to M/1:
https://clubgti.com/forums/index.php?threads/fusebox-faq.219775/
