Piping for sill & arch extensions “clipper kit”
(In Topic #228457)
Any tips on fitting them?
You need to rub down with bit of sand paper the inside lip and apply a dab or 2 of glue.
The long ones for the cill are worse you’ll need to rub down the flat area that goes against the cover then apply contact adhesive to stick it.
I presume getting the piping in the right kind of plastic is not an option?
I can’t see that this is going to work satisfactorily….
A massive disappointment that this company sell this stuff - in my opinion it’s not fit for purpose
So it’s not bad.
They need to be applied the body kit first.
Then onto the car.
If you?re going to produce parts at least make them fit for purpose
These are after market so are made from soft silicone as opposed to the OEM ones that are harder.
These flop all over the place so need either a double sided tape or glue to affix them on to the kit before installing.
It’s a pig of a job tbh.
I key the surface areas before trying to fit them.
I think originally I was told they were double sided tape.
They look really good in the packet lol.
It’s just very disappointing.
Also, it’s sold as individual bits so there’s 6 in a set, two long sill bits and 4 shorter arch bits…. why not supply in a roll enough to do a car?
I feel cheated because it’s not the same material, and ripped off by the way it was sold…
It’s a bit like the repro bumpers I bought from Vw heritage, they are an absolute joke as well
