Pin removal from headlight switch
(In Topic #222066)
And can I buy a replacement pin?
insert a PIN or small Jewlers screwdriver in the recess under the main pin and pry it up that is the Keeper, once the keeper is out of the lock you can pull the pin and the wire out the rear.
Most parts places that I go to on this side of the pond have pins in the "Help" section.
Last edit: by Briano1234
Regional Host NE
through the finger even
worse behind the nail
