Need help pricing Mk1 GTi Cabriolet
 Hi Guys,
Unfortunately I feel the time has come to sell on mk 1989 MK1 Cabriolet.
Bought as a project a few years back and with kids and a camper I don't get the time to use or work on it.
Spec is as follows:
1989 (G) Mk1 Golf Cabriolet GTi Project
Approx 134k
Owned since June 2018
Helios Blue with Blue Quartett interior (blue with red check)
(doorcards are not original)
Manual Roof
Manual windows
Crazyquiffs 3 point rear seatbelt kit installed
15” Porsche Teledial alloy wheels and spacers (refurbished and powdercoated with new centre caps)
Mk2 Golf GTi 16V engine installed
Using Standard KR ignition
Twin Weber 45 DCOE Conversion (Purchased New July 2020) will need properly setting up
Facet Fuel pump in original pump location
Filter King regulator under bonnet
Fuel Pressure gauge
VDO Gauges in Centre console
Billet Aluminium alternator adjuster
Set of Pressed numberplates (Not fitted)
Vauxhall Corsa radiator with twin 11” Cooling fans
Badgeless Grill
Purchased without bumpers but full clipper kit with car front and rear bumpers have been fitted but need painting.
MOT expired 26th April 2019
Can anybody help to price this?
Ryan
HI Ryan, did you put the engine and everything in?  so you know cost, purchase price ,manhours,  then is it running? does it run?  wipers missing with rack it looks? Hows the rag top ,rear window frame? interior? number plate plith on front missing? hows rear number plate held on. ,  stiff like this makes people barter harder.
Prices can be anything from 1000 to 1101 , if all parts there and only a matter of refitting for MOT then  you can ask for more realistic price. PUT location and someone may pop round of the forum and have a look, maybe help with valuation
I search ebay / autotrader / gumtree for stuff and then look at what ive got and decide from market prices and the cost to me what i think its worth.
regards
On the drive
Myvalver 89 GTi Grey mk2 16v
Hood looks shrunk Kenny.
It’s frowning above the side glass.
Re: Need help pricing Mk1 GTi Cabriolet
Ashman86 said
 Hi Guys,
Spec is as follows:
Approx 134k
Manual Roof
Manual windows
Fuel Pressure gauge
Badgeless Grill
Ryan
One picture doesn't tell a true reflection of the car
Sent from my SM-G955F using Tapatalk
These are the main problems which will significantly affect the value. Why were twin carbs fitted (to an injection car) and the work not completed?
If that's done and the car has an MoT (everyone wants an MoT….) its value will truly reflect the car. Otherwise it could/should be considered an unfinished project.
Put it on ebay or similar auction site with that description and a dozen pics and the market will decide.
My guess would be the lower end of the cabrio price range.
EDIT. This recently recommissioned, working, MOT'd, 16v modified (with original injection), similar-ish mileage, tidy-ish cabrio made £5,400 at this Aprils Mathewsons auction, so that gives you an idea of that that max yours could do if it underwent the same work to get it to the same condition.
Without all that its a £1000 orphan in my opinion.
https://www.lotsofclassics.com/vehicles/4c2a6234-cc2a-4e88-9531-a4dadf61be1c?pgid=kjwyvlxm-6b8eb4a7-6dac-44a2-b4fd-f677f8a2ad99_43
Last edit: by Early-1800
If it was mine I would expect to sell for between 1000 - 1500. It may be an idea to eBay off all the modification parts separately. It’s the variation from standard which hurts the value most. Probably worth about the same with no engine, that way someone might buy the engine separately , and the same with all those non standard parts. It depends if you have the time to be eBaying and dealing. Otherwise your best bet is auction the lot on eBay and let it find it’s own value
