need advice on engine swap
(In Topic #210956)
regards
lewis
if you wanted to run it on electronic ignition (Id recommend you try) then you need a coil, spark module and the wiring loom between them. you may need to run an ignition live for the coil as well, if your coil live is purple/white then its a resistance type wire and wont work for electronic carb
