my car wont start
(In Topic #210153)
mk1 golf gti 1.6 turbo technics
my car wont start
My Daughter called, said dad the car won't start, and it made a popping noise…..
Yes that is a Snapped belt… well a few teeth stripped…
my car wont start
Even if its a strip down and rebuild, I'd levy its still cheaper than a conversion, often the conversion engine will need the same care after so long… and well, even the cheapest conversions aren't all that…
As also said, if theres been work recently, id have the basics checked… timing etc
'83 MK1 Golf GTI
'02 Land Rover Discovery 2 Td5
'08 Audi S3 2.0 16v TFSI
I paid £1600 ish for mine doing, new bearings/ rings/ gaskets/ seals etc
Head refurbished, new guides and what not. Everything given a once over, and refreshed accordingly basically.
I did also have my gearbox sorted in that price, needed a few bearings and planet gears… but wont they all…. I was just being a tart and didn't want to hear any dodgy noises I couldn't explain
But if its a project/ toy and you do want to keep it, I'd do it in stages… value will only go up most likely, and that engine is special. Dispel any engine swap ideas …
I'm unsure on Turbo Technics engines specifically, but I know my Janspeed turbo stuff doesn't use any special pistons etc, It might be you could get away with a refurbed or new to you standard 1.6 engine and bolt your turbo bits to it….
Either way, keep us updated in the projects area on how you get on
'83 MK1 Golf GTI
my car wont start
And had the same conclusions as you, enjoy what you have… do it in stages at your own pace. These things are only going one way in price… so just stick with it and you wont go far wrong
Most parts are cheap, and used over decades of Golf/Jetta/Passat/Transporter platforms .. you'll find the 8v, albeit updated all the way up to the 90's… so most bits are plentiful.
Bit like fords I guess …
'83 MK1 Golf GTI
Looking forward to updates
Sent from my EVA-L09 using Tapatalk
'83 MK1 Golf GTI
Last edit: by shaunmmk1gti1600
