Mot fail lighting issues
(In Topic #221641)
So its failed mot, can someone explain the lights to me??
Outside lights are side lights and main beam, when i out full beam on the main beams go off!
Inside lights full beam!
Is this right?
If its not right how do i sort it!!
Mark 1 golf gti convertible 1987.
New roof and interior, new sound system,
New lights, grill.
New lights, grill.
You need to check that you have 3 wires going to your headlamp plug: dipped beam, high beam and earth.
Hope this helps
2001 Zafira 1.8
2001 Zafira 1.8
Most modern cars with different lenses within the light work this way anyway
Current rides:
New lights, grill.
New lights, grill.
Hopefully its just a case of faulty bulbs
New lights, grill.
New lights, grill.
You will be removing the high current load off the switch, and only use the Switch to supply pick current to the relay.
There are kits available for this on Ebay using ceramic plugs for the High/low and for the Inner Highs a separate wire is run.
The kits are cheaper than you doing it yourself now. Usually 20 bucks.
When you Turn the headlight switch on with key out, you get the Parking lamps only.
With the Key on, Not start, you get the outers on low.
with the highs selected you get the outer lamps and the inner high filament.
Usual suspects are the Grounds (lord knows they are a flaky lot.).
The inners have a separate fuse for each as well as the highs, and the lows have a separate fuse as well. So there are a total of 4 fuses for the headlights 2 for low and 2 for high.
Bulbs go bad, as you usually don't see them do this.
When ever I hear of the outers not working on high it is the separate "high" filament for them…
Here is a 2 relay setup for the lamps.
Here is a 3 relay set up that when the high is selected you get the Low beam filament, and the High beam filaments (so more light)…..
The difference in voltage from before and after is usually 1.5 to 2 volts.
Before voltage to lamp:
After Relaying voltage to lamp:
With the relay you are shorting the run of wire to the lamps by about 8 feet, and they are closer to the battery.
Here is the how I did that… I used Honda Brackets from a 89 to hold my relays.
Relaying your Head Lights | Volkswagen Owners Club Forum
typical 2 relay kit avail from ebay… make sure that you get a kit with Ceramic Sockets as they take the heat and higher voltage and current better.
https://www.ebay.com/itm/2-Headlight-H4-Headlamp-Light-Bulb-Ceramic-Socket-Plugs-Relay-Wiring-Harness-Kit/262483542712?epid=1973689229&_trkparms=ispr%3D1&hash=item3d1d3d02b8:g:FGgAAOSwQNRXLlAl&enc=AQADAAAB4KX%2FKt4E1xf3SDqEdBclaYarAyLoO1V4PwFMgyJIwEIgjq3yZnEmiYbrZKGKO%2FvTM8lDd2WEDZVYmnLzGHVrRHtCMZQ5bP6ACn0sGjECF6xIeVjz0mtSqBPgqpZFX4tZcCCX0vROAEaesLiGVpfTWxJtkWanRorvgmFgqK7FA%2BZe%2Bjo8SGnp941N87S8%2FxyO3x2yINk4k8%2FsCArS9%2FkTUVIJQaL93vDYdPlDI3sik%2BT4QujANd7NdLZy9PHK3TCTvoSYtHG%2BeMR53BFnziQldr7x4XViWT81svQII7BLweIjEGdn10Ag8p9ZXDMH7aYaVwCUiajGmepNwiiGTwcNcnLyyIHgaW2gOj7Qw6BUrFJQl7dyQqI8X9KbVTEcox%2BPUf7%2BEEWMSPxH5LMXQBgv6uPbjFLm7aoZYzjCzcsvvn%2ByxPeYKnsRymFlnHtm%2FQbnjCdY7IZ%2Fgwy82sDlpVvYVpt7wlYEsUHZpYLegVDo4tI2vN7UfR1bJYWayhPx3KBk3JdXbp18B8l7XUpL8o3x4GZYrNWL%2Fd1vz%2FogLnAUodYJcbBYoVYM0%2Fn4InJG9aiS%2Bg97VgGohIAdP4vlD8E5PE5G3Qrrz1UJ%2Fv3KVGydOikZcSr8oqC4pTY%2BOdNB3ss5CQ%3D%3D&checksum=26248354271215c82eea80384f04826e7eaac6bf4b7f
