Mk1 golf cab 16v kr conversion wiring isues
(In Topic #225331)
View topic: Mk1 16V FAQ update (New weblink and details inside) - The Mk1 Golf Owners Club
Any specific problems can then be asked.
In theory, it should be a case of removing the ecu and associated wiring both to the engine and to the fuse box.
I haven't done the engine you have but have removed the injection system from the 1400 16v and put it on carbs.
They'll be bits like distributor and ignition amps etc.
paul_c has done plenty of engine conversions and seems to know his onions. I'm sure he'll be along shortly with some great advice
Ian
If anything, its simpler than the GTI K-Jet injection setup - you'll effectively be disconnecting and not re-using the connections for:
5th injector
Aux air valve
Warm-up regulator
The other ones will be limited to distributor hall sender, coolant temp, oil pressure switch(es).
I don't know what your plan for fuel pump is - are you going to use some other electric fuel pump? If so it would make sense to re-use and re-route (well, use another wire from the fuse box) the fuel pump power feed wire, since the fuel pump relay has a prime and cut-off if the engine stalls. I can't remember the colour/location but a wiring diagram will help you here.
Obviously it makes sense to simply re-use the original electronic ignition control module, I think its called the TCI on a Mk1 Golf?
