MFA woes. Can they be fixed?
(In Topic #214823)
The clock is accurate and the mileage trip is also accurate but that's about as far as it goes!
The outside temperature reads lower than it actually is in the warmer weather (I don't know what it does in the cold!) and it will change by several degrees in one jump and then change back again.
The oil temperature guage reads quite a bit lower than the VDO gauge I have fitted and that also changes suddenly, for example. it could be reading 102 degrees when the VDO is reading 120, then suddenly it could be reading 88 but the VDO is still reading 120! If I give the car a bit of stick the VDO might climb to say 130/140 but the MFA reading will drop!
The MPG says 99.9 on both settings, if I reset it then it soon goes back to 99.9. I can dream all I like about the cars fuel economy but it only gets mpg in the low 30's!
I'm not sure about the average speed readout, it always seems a bit low to me but I've never tried to work it out.
I have searched and read posts (including one that was several pages long) but I haven't found a solution.
Can anyone shed any light on this or point me in the right direction as to where I should start?
Cheers.
I get similar readings on my Scirocco and that has a VDO gauge and no oil cooler, the Scirocco will creep up to 120/130 if driving down the motor way on a sunny day at 5,000 rpm for an hour.
I would check the condition of the wires especially at the spade connecter as they can just be hanging on by a few threads of wire.
Do you have a heavy right foot or lates of town driving to any get in the low 30 ?
I easily get 38+ mpg in my car when I commute to work and I do reach 60 mph along some of the nice country roads.
Is there a way of testing the outside temperature sensor?
So it's an Audi 80 gauge, econometer reads in the 40's when on the flat at around 60 but if I work out the mpg when I fill up it's around 33mpg. I don't get on the motorway with it very often.
On the subject of the VDO gauge, I've just had a look and I've swapped the wires around on the VDO and MFA oil temp sender (I did this a while ago as the VDO was reading very high). The original sender is white, the new one I installed for the VDO is black. Just been reading online and I'm wondering if the VDO should have a blue sender (180 degrees) which would explain the VDO gauge anomolies. Could anyone confirm this?
Going back to the main issue, is there much I can check on the MFA etc or is it old electronics gone terminally bad?
I'm no electrical genius like rubjonny or briano1234 so I could be wrong so hopefully they will chip in and help.
Other things to check is earth wires, have you got 2 on the rocker cover, a big thick one going to the coil bracket and a thin wire going into the loom with the dissy connection, water and oil temperature wires?
That's how it is on my 1988 cabriolet..
I have a yellow/black wire on the rocker cover and a green black wire to the oil temp sensor for the MFA. I can't see any other wires on the rocker cover. I don't have a big wire going to the coil bracket either. I didn't check the dissy or water temp wires (I'll have a look tomorrow). Water temp gauge in dash works ok (I think).
Most of these sensors must have a resistance at given tempertures so I can test the resistance of the sensor and also give the gauge a resistance and see what it reads. I don't know how the MFA gets all of it's data to come up with MPG though, I know there is a transducer onthe speedo which mine must be getting as it knows trip miles and average speed so something else must be wrong for it to tell me I'm getting 99.9 mpg.
Does your MFA tell you you're getting 38 MPG Mark?
MFA show about 40-44 and I'm getting 38-40.
I do live in Somerset so not much town driving even on my commute to work.
Yours being a tin top uses a different system to read MPG than mine, I don't have all those vacuum hoses and the big plug on the gearbox for the shift up and 5th gear MPG I've just 2 wires for the reverse switch on my gearbox.
My MFA does have a mind of its own, 80% of time it works fine and shows MPG, average speed and miles travelled and 20% it does not show those at all!
Everything else works just fine, e.g. Time, oil temp and outside temp.
Mine might just be the connection to the instruments as I'm planning on bulking out the connection with a bit of tape to get a better connection when I need to remove the instruments again for new bulbs etc….
depending on where the vdo oil gauge came from you either need a white sensor again, or a blue one.
check tghe earth to the side of the head for the dash clocks, its a brown/white wire with ring terminal. later cars have an extra earth strp from the rear corner of the head to one of the coil mounting bolts so thats worth a try. make sure the gearbox earth is good as well
The MFA oil temp reads around the same but suddenly it will drop by 10-20 degrees. The ambient temp reads about right (similar to my van and the wifes car) but that will also suddenly drop by 8 or more degrees and the mpg reads 99.9 al the time. I have the earth to the rocker cover (brown/white) but I will put a link from the rocker cover to the body and see what happens.
I've remade the earth to the rocker cover and also ran a 6.0mm earth from the rocker cover to the battery earth terminal. It has made no difference to the MFA readouts so I'll be removing the dash in the near future. With the dry weather we're have at the moment I'm still enjoying the Golf so the MFA will have to wait.
mark1gls I've just filled up and worked out the mpg and on the last tank I got 37mpg. That was a mix of enthusiastic driving and steady driving all on A roads and town driving so on the motorway at a steady pace I should get a bit more hopefully.
Updates to follow…….
As you've done the only way to be sure is to record the usage by filling the tank full. Driving till it hits about 1/4, fill again and do the maths.
But then I'm sure everyone knows that anyway! 😂👍🏼
There has to be an app for that…..
I only know of two.
The calculater on my phone or pencil and paper for us oldies. 😉
But Brian what fuel consumption do you get from your petrol Cabrio using the Imperial measurement per mile on average? 🤔 ☺️
Sent from my Smartphone 📱
1 Imperial gallon = 1.2 gallons US.
In the 6o's driving through Canada they had Imperial Gallons.
On my 90 Cabby with 1.8 Digifant, 5spd, I averaged 40mpg on the highway @ 70mph, running 93 octane. In town I was getting 29-35 depending on if I was running a/c and or lead footing it. Cost wise the difference in octane was about 2 mpg so was the additional 50-75 cents difference between 87 and 93 Octane worth it, well to an accountant probably not.
On my 81 Diesel Rabbit 4spd the best I got was 59mpg cruising the interstate @ 55mph over the years and a 5spd swap I sold it getting 42 mpg in town when the thing was 20 years old.
On my Current Cabbies, 92, and 93 1.8 Digifants both with TNA Automatics, I get 19-22mpg in town with the difference being with the a/c on or off. No real difference between top up or top down. When I cruise the interstate running 93 octane I get up to 26-28mpg on Average.
I do know that in the oldie days, my 67 MG Midget consistently got 55mpg on the interstate, and my Rover 3500S V8 running 130 Av/gas Flew Down the road, and I didn't care about the mpg then….what with gas being 25 cents/gallon…..
So when I hear my Daughter praise her Prius getting 55mpg,
I would remind her that in the old days, I was used to getting 55 MPG in my Diesel Rabbit, or MG, No Batteries needed, and nothing to distract you from the enjoyable driving that Top down whistling hair and rumble from the exhaust provided….. Who needed Cup holders or Radios and Blue-teeth was what you had when you went to the dentist to show you plaque.
