Kjet Pop then dead
(In Topic #230144)
Basically driving along as normal and there was a sort of pop/bang sound from the engine, and it conked out. Not instantly, but after a few seconds it gave up. The fuel pump stills sounds with ignition, starter turns, but there's no sign of anything happening.
Should I just pay up?
I've left the side light on. Think the batt will last night?
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Anyone know of a good thread with usual k-jet dianostic steps? Can't seem to find one.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Kjet Pop then dead
I would check compression in case the timing belt has snapped, check for fuel pressure and check for spark.
Go from there ?
Haynes manual also has some basic test info in it as well.
There is a FB group - Bosch CIS Wizards that might be a good reference.
jazzydog said
Are you sure it’s a fuelling issue?
No. Didn't think it was.
Go from there ?
Okay, thanks
paceman said
It's a long thread, but there are plenty of suggestions in here.. https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=helllllpppp%2Fk-jet-experts-please
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Good luck, hope it's not too serious…
pull a lead off and does it spark when held near the block when cranking?
Pull an injector out, does it spray petrol when cranking?
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Best Dragons Den voice, "I'm out".
the_whip said
So just pull one of these off, and hold it near the block while trying to start it?
Early-1800 said
Yes but look likes a 16v so not factory and poss lots of none standard things going on with wiring, fuse box, ign and fueling.
lmao,
"Retreat!"
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Life Member
Mine packed up earlier in the year and made it impossible to drive, back firing pops and stalling constantly.
Once replaced - no more issues (for now!! 🙄)
Anyway, I did some tests…
Spark plug smelled of petrol, and there was no spark.
I then did tried this (kinda guessing my way through):
I checked the resistances on the coil:
0.9 and 3.12K seem out from what they should be. Enough to stop the engine starting completely?
Thanks for any advice.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
I picked up a second-hand coil on eBay. Resistance was above 7K so within proper range. Popped it in and engine started instantly.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Great post with conclusion.
Here is a quick tickle test by my Friend Ron….
No spark?
Here are some spark tests, post your results.
Put the business end of the coil wire where it can arc to ground without shocking you or starting a fire. Ignition switched on for these tests.
With the plug removed from the Hall sender, with a paper clip or whatever as a probe to the center wire (green/white I think) of the Hall sender harness plug, 'scratch' or 'tickle' that center wire to ground, you should see sparks.
Yes, Good spark every time.
Here, you've just tested, as a system, the entire ignition system EXCEPT the Hall generator itself.
While the Hall plug is in your hand, measure voltage across the two outer pins, I'm not 100% on this but I think it should be 10VDC. I think you've done this already.
11.25 V
Reconnect the Hall, back probe the center, green/white and connect your DVOM between center to a known good ground.
Slowly rotate the crankshaft by hand, as the shutter wheel alternately blocks/opens the Hall opening, voltage should go from ~zero to ~10VDC.
Hope this helps others in the future.
the_whip said
For anyone following this is the future…
Well done. Note there are two types of coil, ballast and non ballast. One runs at 9-10v and 12v when cranking so you get 20% extra big spark for starting.
I think most VW ones will have been ballast since the early 80s? but they could have been mixed up when the engine conversion was done? If so that may be why the wrong failed when being run at the wrong voltage?
