horn not working and hand brake light not working!!!
(In Topic #208993)
thanks Mark.
Website Manager
Website Manager
If the fuse blows then you have a issue with something shorting to ground.
The horn uses a switched ground to the horn, so it could be that your horn is shorted, that is if it is the horn fuse that is blowing.
The circuit for the horn is:
Ground on the steering shaft low up through the shaft to the slip ring, the depressed button completes the path to the relay the relay picks and switch ground on to the horn. There is 12V full time to the horn.
see: http://forums.vwvortex.com/showthread.php?8241841-My-horn-finally-works!
But telling us which number of fuse that blows helps us help you, after all we are not clairvoyant.
Hand brake is the only connector in the dash that you can put in backwards.
so your seat belt and parking brake light can fail to light.
The hand brake has a switch on the Tunnel that has a single wire, it can become mispositioned or broken. make sure that the switch is making contact when up, and breaking contact when down. They can go bad, and debris can insulate them so cleaning it isn't that out of the ordinary.
D/7 can be used for the coolant level control relay, also for some of the electrics on the carb depending on what engine it has
18 also feeds the accessory 'G' spades number 2 and 5, these go to things like heated washer jets, electric windows etc.
for an 84 GL I'd start looking at the carb wiring, then work back from there
Last edit: by rubjonny
