Horn Issues
(In Topic #228458)
So I’ve recently been using my Mk1 more often than usual due to nice weather, I’ve found out that I’ve got an issue with the horn. As I go over speed bumps or hit a pot hole my horn goes off. At 1st I thought it was the connector touch the stalk screws but I put some insulation tape around it but it didn’t help. The horn still goes off when I hit a bump or pot hole, can anyone help me resolve this issue??
Thanks in advance
The horn has 12V to it full time on the blue/yellow wire, and the ground is switched via the button on the stalk via the steering rack and a ground wire through a relay.
typical horn circuit.
