Help with indicator led on dashboard
Hello guys need some help, after driving around today,  I noticed that the green indicator flashing led on the dashboard doesn't always illuminate when i engage the indicators and is intermittent, but I can hear clicking of the indicators in the fuse box, my question is what could be causing the illuminating green flashing led on the dashboard to only work intermittently, and is there anything I can check, all help is greatly appreciated in advance
Add a new Ground to pin 2 (brown) on the main connector to the firewall, and check your fuses, there are 2 for the turns the hazard fuse low number like 4, and a higher one for the turns f19 or so.
Take all your bulbs out for the turns and clean the contacts and ground points.
