heater control valve cable, and bulk head holes
(In Topic #222826)
what goes where??
Got an 83 GTi, although Cabby's may well be similar.
Couple of questions.
- Where should the cable that controls the interior heater flow valve be routed? Does it go under the brake servo, behind it, in front…? I can't seem to find a route that looks right. For ref I have the cable coming through the bulk head at point 3 in the pic below.
- Assuming the cable does come through No3 - what the heck at numbers 1 and 2 for?? This Q is probably 83 GTi specific.
Thanks in advance!
Jason
Regional Host NE
for pistol this afternoon send me your number and
i will give you ring when i am under the bonnet
Did you take any notes?
J
Regional Host NE
i will look when i get in from work mate
Regional Host NE
Interesting. Can't see the heater control cable on any of those grommets. Must be another hole somewhere! I'll keep looking.
Thanks again!
J
Regional Host NE
to work this morning you can see the heater cable
going between the two large harnesses
Regional Host NE
nicci21paul said
not the best image done in a rush coming out
Thanks!!
Pistol said
Jason, page 2 of my build thread. Just after engine was taken out. Heater cable running in front of servo across to the heater valve. Second pic you can see the black cable coming through the bulkhead just below the scuttle drain.
Thanks Pete!
