Headlamp /headlight switch query 323 941 531F
(In Topic #210874)
advice sought re. replacement switch
Reading around, I learn that the overheating problem could have been avoided altogether had I fitted an upgraded headlight loom complete with relays. Suffice to say I now have one on order!
Thanks!
if you can get the right plug to match the later 10 pin switch then you can probably re-pin it comparing the old and new terminal numbers depending which terminal is missing.
the earlier 8 pin as above but issue with those is the looms are made differently, the dash lighting feed is fed from a different location and so isnt fused unlike later 9 & 10 pin variants so I would try to stick with those if you can
