HAD ENOUGH NOW! PLEASE HELP..Falling out of love with my car ol
(In Topic #210849)
Tuning issues, red hot manifold, co reading ignition timing moving etc please help
Today's issues
Red hot manifold?!
I've been tuning and tweaking my mk1 golf gti dx cabriolet 1.8 8v
It's had new piston rings, head rebuilt and skimmed..
I've timed it with a strobe to 6*btdc, before that I set my co to around 1.5% ish and my idle is at or around 1000rpm steady no shakes etc.
My exhaust manifold is glowing bright red? Sometimes at idle too.
I'm unsure what order I should do the steps to tuning at you see and I've limited times I can go to garages and ask to borrow their exhaust gas analyst equipment haha
Some pictures
I set the co this way then turned the dizzy to 6* btdc this would effect the reading I bet? Also if I move one the other changes. So eg I move the dizzy the co changes, I move the co the ignition timing appears different it retards it usually?! I move the idle screw which is wound in quite far now with little room for adjustment inwardly the ignition timing changes again. I'm stuck n lost with it
I would set up the timing first, then mixture for CO. Your idle seems too high though. I think warm spec is about 8-900 rpm. I've got Autodata book with all the numbers in but not at home sadly.
If it's running too hot then I'd think too lean but 1.5% CO is good.
rubjonny may be your man to help. Have you checked out his tuning guides? you'll find them on the net no problem.
I think it's his for the MK2 you'll need - essentially all the same points to check mostly, but worth checking you've not missed something obvious.
Apart from the glowing manifold, are there any other issues, hunting, erratic running/idle etc?
I've wrappped mine so can't say if mine glows during tick over.
where should I have each thing? So idle when warm 900 not 1000? It's shaky at 900 and furthermore it would idle lower than that still during warm up?
Co? Should I aim for 1% or 1.5% I read something rubjonny said about 2%
And what order should I do it in?
could you show me what slot you mean I'm having trouble imagining how that would look? Confused a bit but I think you may be onto something here ?gafo said
Glowing manifold is a timing issue, had it on g60 and the crankshaft pulley had worn the slot in the crank,timing looked good all marks lined up but it was out. Might not be same as dx but I'd double check timing
I don't know where to buy the in the U.K. but I'm sure many others do.
Don't need the engine running and only the key in and on.
Vacuum hoses can be bought in Bulk, and about 3 Meters of the 2 different sizes are needed. In the ETKA they list the MM diameters and show a "Bulk quantity."
Hose in rolls of 5 meters order unit 5' then it says 3.5X3 then in the next line it says shorten to 120mm. This is off one of the vacuum hoses for the Dizzy….
Over here I can go in to any good automotive parts place and get various diameters of Vac hoses by bulk, and usually they print the MM on the label as well as inch diameters for us that are Metrically challenged.
