golf mk1 1.1 engine start problem
(In Topic #222816)
When i start the car i have to bump the acceleration pedal once or two times to idle, but that did not always happen. When i purchased the car a couple of years ago it used to start very well.. The car died a couple of times due to the carb issues about 2 years ago, but i have cleaned it properly and put everything back just the way it was but it developed this problem.
The car runs very nice, it idles normally, the only problem it has it is the starting.. could this be from the starter motor? when the engine is hot it seems it would start from first but you can hear a weird noise from the starter and you have to press the acceleration again to idle.
I would appreciate a couple of suggestions, Thanks
