Fuel pipe needed
(In Topic #227925)
Fuel leaking
Regional Host NE
could you narrow it down a bit
maybe an an image attachment
Fuel pipe needed
Sent from my SM-G955F using Tapatalk
Regional Host NE
Fuel pipe needed
Regional Host NE
one lying about mate
Fuel pipe needed
Regional Host NE
Fuel pipe needed
Regional Host NE
the dividing fence to the neighbours garden gone west
Regional Host NE
Regional Host NE
Fuel pipe needed
Rubber Fuel Hose.
Ask nicci21paul to measure the OD and ID of the cut hose, then order a section.
On the drive
Myvalver 89 GTi Grey mk2 16v
Fuel pipe needed
https://vwgolf1.com/index.php/product/fuel-hose-reduction-pipe-11-to-9-mm-533201543/
https://www.heritagepartscentre.com/uk/533201543-fuel-pump-connector-hose.html
I believe the hose goes from 11mm down to 9mm so off the shelf fuel 1 size fuel hose will not work.
Greenmk1 said
Hi Kenneth, its I think 12mm and 9 mm on the other side, if I was to put a 12mm pipe on both ends ethanol proof, and proper use fuel clips would this be ok. As I don't want fuel leaking due to wrong diameter pipe used on the smaller pipe.
Pretty sure 10mm will fit.. most hoses have a bit of give ..when warmed up in boiling water. so would stretch to 12mm ,and definite close on 9mm But if the hose mark has identified from vwheritage is correct then its your choice.
As regards to rubbers and o rings they all have shelf lifes, and pretty much everything oem on golf mk3 is past use by date…so mk1 its even more so. At the unit ( Kennysclassiccars.co.uk) ive found 2 boxes of o rings all are unused but brittle..and unusable, these are rubber and nitrile.. and under 10yrs old.. which is why I say make sure hose comes from reputable retailers.
On the drive
