Fuel hose size??
(In Topic #222624)
Size of fuel like needed??
The last owner made a hash up of everything so i'm just renewing parts and making sure everthing is as it should be.. it runs like a bag of nails at the mo.. Question is what size rubber hoses should i have fitted on the feed, return, pump to Swerl pot & carb feed from S pot
or
does it even mattter??
At the mo its got a mix of 6.3mm feed, 5.6mm return, 4.8mm pump to pot & 5.6mm to the carb.
Just replaced the Fuel pump, swerl pot & a nice new inline glass filter.
Still need to add the missing carb heater, link up the hedgehog heater, fit the banked off vac pipes & fit correct jets.. then set the carb up.
On the drive
Myvalver 89 GTi Grey mk2 16v
There used to be a two part air intake shroud that sits behind the o/s headlight. There's not a lot of information about it but i am waiting for a part to arrive and will see whereabouts it fits and if it makes any difference.
