Fuel filler neck
(In Topic #220514)
Cheaper than buying a cabriolet filler neck.
View topic: My Daily drive 1988 Gti cabriolet - The Mk1 Golf Owners Club
Looked on eBay and tin top filler necks have gone up, I paid £25 for mine.
Buy a new rubber hose which joins the filler neck to the tank as they go hard over time and become a nightmare to fit, also get 2 New jubilee clips as you might as well fit new ones while it’s apart.
Plenty of paint/protection on the new filler will help a lot as the finish it comes with is only to stop it rusting while in storage, don’t use Hammerite paint as it’s to hard and chips off way to easy, I used it on my old white filler neck you can see in my thread and even though I cleaned it regularly and waxoyl the wheel arch every couple of years the filler neck only lasted about 8 years but my car is a daily drive…
I tried bending it after heating it up with a blow torch but could not do it and I felt the pipe would crush and be distorted once bent and not make a good seal with the rubber hose.
In the end I took both filler necks (old and new) to someone who had to cut a section out of the pipe and weld the end back on to get the correct angle.
Pictures etc is in my build thread I posted the link to in my last post.
Regional Host NE
i have a couple i will see what they are
like mate
I've seen people make a sort of pump to suck the bits out before as well.
The two different ways above you won’t need to remove the fuel tank as you will access it via the sender hole.
Search online for more info etc…
To remove the fuel tank you need to remove the rear beam but be very very carful with the 4 studs and bolts which hold the beam onto the car because if you snap these studs off you need to cut and weld in new studs.
Start by cleaning the threads of the studs and soaking them in Plusgas or similar penetration oil over the next few days(WD40 is rubbish so avoid it)
Best to buy a new tank, they are £125 ish new if going though hassle of removing the old one.
https://www.ebay.co.uk/itm/PETROL-FUEL-TANK-SEAL-VW-GOLF-MK-1-CONVERTIBLE-1-6-1-8-82-93/382567689444?fits=Model%3AGolf+Cabriolet&hash=item5912cface4:g:CigAAOSw0oBZw-cB
Found some info about sucking the tank out. Early 40l fuel tank are slightly different to later 55l tanks like yours as we don’t have a built in swirl pot etc.
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=how-to_2/fuel-tank-cleaning_3
BE VERY CAREFULLY with fuel vapour as you don’t want it all to go up in flames and make sure when working on or in the fuel tank you have plenty of ventilation in and around the car.
Last edit: by mark1gls
Use a electric or air impact on the nuts for the studs, as they usually won't torque shear the bolts that a Breaker bar or Ratchet will.
Then after Clean the threads well and use never-seize.
Be mindful of the Rear Brake lines (rubber) as it wouldn't hurt to have replacements on hand as they are probably cracked and chafed.
