Front struts for a Mk 1
(In Topic #219006)
Plea for help to source front struts
What I have found over the years of Rabbit/Cabriolet ownership is that the struts only get damaged by stripping the internal or external threads, and or by being kinked.
As if yours are original then they have the fluid filled cartridges, that you remove then insert the cartridges in to them (you also want to add a little ATF it the cartridge to assist in heat dissipation.
The other part of the equation is that you have to keep the weep holes on the lower spring perch free of debris so water will drain off the strut perch.
How I do the strut replacement.
Replacing Front Struts, and Mounts | Volkswagen Owners Club Forum
Ebay and classifieds are a good place to look for hte bare cartridges, there were some places that sell one time use, which means that you can rebuild them.
Bilstiens had a set that you could re-cartridge, and there are coil over kits that you can buy to get the strut tube.
I mean they are steel, and a pretty thick steel at that.
If the perch's aren't rotted out, they should be good to go. I mean I have never had to replace a strut tube, cartridges yes tubes no, and I have had both the internal thread and the external thread. When mine looked like garbage on my 81, a wire wheel on my drill, primer, and 3 coats of Poly sating black they looked better than new.
Most ones you can buy from shops are 2nd hand and have been blasted then powder coated so might be worth getting yours done?
Welcome Leskane1, got any pictures or more info about your sportline?
Start up a project thread or post up some info in the newbie section.
Got a full set of knackered fronts for £30
Blasted and powder coated in black for £60
Not a cheap affair but you'll never have to do it again
Current rides:
