Front brakes from golfmk3 GTI to golfmk1 cab
(In Topic #218181)
Brakes
Does Somebody knows something about those brakes from golf mk3 it fit in the mk1 cab. Golfmk3 has 5 wheelshols, is it possible to use calibers and ceeriers and by some golfmk2 256mm discs and mount on golfmk1.
These spec calipers and carriers will work with no issues.
Girling 54 type calipers will work if you have the correct carrier brackets.
sounds like you've found some so buy them and try it.
Ian
