Front brake pipe routing
(In Topic #232935)
Pics anyine
Has anyone / can anyone tell me where the pipes go - I.e. which pipe goes where in the cylinder. Obviously got 2 front, 2 back and one connecting the "junction"
Thanks in advance
Some Cabriolets have a rear load sensing proportional valve set up, and later ones don't as the proportional valves are on the mc at the rear lines. and usually located on the front left side (as you look at it) and the right rear port of the mc, then the brake line attaches to the valve.
I've got a square block bolted to the servo bracket with 2 side exits and a bottom exit. Then I've got two bottom exits front & back on the MC, then 1 side exit at the rear on the drivers side.
The other 3 ports are a screwed blank and two switches/sensors.
See pic - it'd be a 5 min job fitting up as all pipework ready to go but not sure where they go.
My old camera died and lost some pics on dismantling hence the "panic"
