Front Brake Disc Retaining Screw - Knackered
(In Topic #225146)
MK7 Golf GTI
'97 Mexican Beetle
MK2 Scirocco Scala 8V
'97 Mexican Beetle
Go Buy a set of Left-Handed Drill Bits.
WIth a reversible drill, place a drill bit that is a tad smaller than the diameter of the bolt (not the head usually 3/16 of an inch works .)
https://www.harborfreight.com/left-hand-drill-bit-set-13-pc-61686.html . usually about 15-20 bucks for a set.
https://www.amazon.co.uk/slp/left-handed-drill-bits/gcx552yucghn7oe
Place the drill in reverse, and center drill the head. It will start drilling, then usually bind about 1/2 way in and back out so fast you won't believe it. All of about 2-3 minutes, and you don't have to remove anything.
The Screws are M6X16 . p/n N 10648301
Heres a link,
https://www.google.com/search?q=drilling+out+bolt+with+left-handed+drill+bits&rlz=1C5CHFA_enUS894US894&oq=drilling+out+bolt+with+left-handed+drill+bits&aqs=chrome..69i57.14063j0j4&sourceid=chrome&ie=UTF-8#kpvalbx=_9hXpXrGeMJGcwbkP2J2v8Aw30
https://www.youtube.com/watch?v=Qnqnr_MN2WA
It works…. The second vid is a hoot. The guy can't believe it, and it is a bolt in the wheel well.
Last edit: by Briano1234
You don't really need a screw in there as the wheel and bolts hold it in place.
MK7 Golf GTI
'97 Mexican Beetle
'97 Mexican Beetle
Cack job, done it too many times, but get there in the end. I should invest in some left handed drill bits….
Thanks to all for the advice.
MK7 Golf GTI
'97 Mexican Beetle
'97 Mexican Beetle
I found using an old flat screwdriver and a hammer - basically use the screwdriver as a chisel and create a grove in the screw head - tapping gently with a hammer should get it moving loose and it will undo that way.
Trouble sometimes with drilling, you loose a few drill bits in the process and can sometimes leave the thread in.
