Filler neck help
(In Topic #218146)
Any advice would be appreciated.
The plastic spacer helps to centre the filler neck in the opening in the body allowing the screws to be done up easier.
Dunno why there'd be different ones for the GTI and the carb. Possibly due to the angle of the filler neck as the tanks are slightly different maybe?
If you can afford it then get both as it's the way it should be done.
If not then nothing will go wrong without them. Obviously as you currently don't have them.
Ian
The cheaper tintop car filler neck can be made to fit but it need a section cut out and the the end welded back on…..
