Exhaust manifold removal
(In Topic #203540)
I have a 88' 1.8 8v cab, and In trying to change the exhaust system. I've managed to remove all nuts except one, seems like the inlet has to be removed. Is thus correct?
Some times if you take the strain off the connection as in using a jack to place up pressure on the exhaust, will release the iron bind.
When I have taken the enhausts off of my Cabbies I had one epic fail, and two positive.
The fail broke 3 studs from torque shear when I used a 6pt socket and a breaker bar.
The success was soaking them with a PB-Blaster for 3 days prior 2 days prior 1 day prior, 1 hour prior and then 20 minutes. I started the engine for 2 minutes to expand the metals.
They all came off with the proper use of a 6pt 12mm short socket, a wobble extension and a Air impact wrench.
I had 3 studs back out on one of the 2 cabbies, and I went back with Stainless Steel Hex Drive Studs, easy to install and tighten, I also used never-seize on all nuts studs and what-nots.
When I installed a header on one of them I had to grind the header to clear the intake. So I suppose you could be having that sort of issue where you will need to loosen your manifold to get clearance.
