Engine management box.1993 Mk1 golf clipper.
(In Topic #221000)
Removing ecu
Any suggestion very welcome. Paul.
Last edit: by Oldman
Remove the connector off the ecu
Remove the 2 screws that hold the bracket at the top.
Remove the connector of the ICM.
The bracket is on a slide fit at the bottom so scoot it off the slide holder.
Now clean your rain drain at the strut tower, and all the crud.
I have followed your instructions and it slides off the lower mounting towards the front of car.
Unbelievable amount of mud, leaves, and general rubbish solidified under the ecu. I have always kept the two drains clear so was amazed at how much rubbish was there.
Many thanks again for the information.
Paul.
Paul.
Here is mine with clean drains and a Debris guard.
