Engine cutting out
(In Topic #221995)
My 1991 Clipper 1.8 is giving me headaches trying to figure out why it runs for only less than a minute and then cuts out.
I have had the fuel pump, reservoir and filter replaced and that seemed to do the trick. The fuel flow seemed much stronger through the lines to and from the Weber carb. However, the fix lasted only until I got it home from the garage. The next day it was back to its old tricks. I drove it for about a quarter of a mile and then it cut out and when restarted it would run for less than a minute and cut out. Impossible now to take it out on the road without a back-up tow car.
Any thoughts on possible causes would be appreciated.
den
Have you checked there isnt muck in the fuel lines? this can cause something similar too.
Last edit: by Vic
