Door handle
(In Topic #229874)
Moving
i will take a pic of my handle tomorrow and send it you
The screw at the front is under the center strip.
Pry it off carefully.
The bit for screw has broken. Time for the metal expoxy until I get one from Ali
€ 8,35 14%OFF | WOLFIGO Car Door Handles Lock W/ Keys Outside Exterior Front Rear Left Right For VW Golf MK1 MK2 Jetaa MK2 191837205A,191837206A
https://a.aliexpress.com/_BT9K9T
€ 4,80 39%OFF | Front Left&Right Exterior Door Handle And 2 Keys For VW Golf MK1 MK2
https://a.aliexpress.com/_B1KN5t
Regional Host NE
by the link
Change your pawl as said above otherwise does not lock!
Last edit: by supeone1973
Choose Exterior
To the upper left are 3 bars in a square.
DIY Guides
Replacing Lock Cylinders opens a PDF that you need to view.
It shows the original link at VWvortec but since they changed format all the old links are dead. IE: My how-tos that were on page 3 of the faq's is now page 4, it is still post 75, but no longer at the bottom of the page.
Here is the original article.
https://www.vwvortex.com/threads/how-to-repair-or-re-key-door-locks.3496179/#post-42591508
supeone1973 said
Hi I think that file been closed.
http://cabby-info.com/Files/RepairingDoorLocks.pdf
On the drive
Myvalver 89 GTi Grey mk2 16v
Just saw my ytpo…
http://cabby-info.com/Files/RepairingDoorLocks.pdflinders. linders shouldn't be there….. OPPSY my Bad.
