Does my golf have a break regulator ?!
(In Topic #215640)
To get the correct parts I need to know if the golf has a brake regulator.
B505 YYE
1.6 auto Karmann cabriolet.
1985
Any ideas peeps?
Thanks 👍🏻
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=technical%2Frunning-gear_2%2Frear-brake-regulator
Google image will show you the other type of regulator….
Last edit: by mark1gls
85 could be on the rear axle or on the master cylinder opposite corners.
rear one
https://www.partsplaceinc.com/vw-mk1-brake-proportioning-valve-22902.html
or
http://img.eautopartscatalog.com/live/N306055323.JPG
https://www.eurocarparts.com/ecp/c/Volkswagen_Golf+Cabriolet_1.6_1985/p/car-parts/brake-hydraulics/brakes/wheel-cylinder/?134440138&1&6e83d72e2a84521f1c67d16cb286994290180748&000371
Cars fitted with a regulator have bigger rear wheel cylinders 17mm
https://www.eurocarparts.com/ecp/c/Volkswagen_Golf+Cabriolet_1.6_1985/p/car-parts/brake-hydraulics/brakes/wheel-cylinder/?134440148&1&c9327583c199e35b644662b063ee401f4f1c9df8&000371
If you look at the pictures you can see 1 is bigger.
I don't have a regulator on my 78 Mk1 Scirocco as long as you fit the right regulator you should not find your self facing the wrong way or worse case in a ditch as the rear wheels have locked up before the fronts!!!
If you are replacing the wheel cylinders it might be worth removing the drums to double check or check you can return the items ?
