Cutting out helllllp
(In Topic #225810)
From the back
In tank pump
Under body pump
Fuel lines all the way to the fuel filter
Fuel filter
Ignition module
Fuel distributor (whole top of the air box)
Warm up regulated
Fuel pump relay
Cleaned the earths under the glove box (crown connection)
I think that’s it
Any help would be great
If the clutch wasn’t disengaged wouldn’t it slip and smell bad (it doesn’t)
Get the engine warm and try increasing the idle speed via the screw on the throttle body to 1200 rpm, blip the throttle a couple of times and then lower it to 1000 rpm.
I could be the idle screw is working it's self lose and the car is ticking over on the anti stall device, the sudden stopping could be the device is not kicking in quick enough to stop it stalling.
Its a simple thing to try and is free
Its here. I think you need a 7mm spanner.
http://www.mk1maintenance.com/adjusting-the-idle-on-a-1.8lt-injected-engine.html
