Cuts out after seconds of starting
(In Topic #218979)
Golf GTi 1983 Tin Top
Ok it took a few attempts on getting it running by winding it over and then it fired up and then stops wait a few seconds turn the keys it runs fine and then stops.
So after checking over the basic stuff cant see anything that would cause this.
Am i right in saying this year DON'T have the pump in the tank? there is a pump outside which is constantly on soon as ignition is turned which is quite loud i think this has been wired to run when the ignition is switched on.
Any other things i can check or do?
I am mechanically minded just on diesels though, not had an old style petrol engine for over 20 years
Any help will be much appreciated
On the drive
Myvalver 89 GTi Grey mk2 16v
I managed to get it running. Disconnected the fuel lines from the tank put them into a jerry can of fresh fuel, and cranked it over then I noticed fuel spraying out of the main fuel line, so the dude i bought it of mentioned something about he replaced it with a flexi hose and where he joined it to the fuel pump hose it was leaking.so after doing a quick hillbilly repair job cranked it over for few seconds and she's running,
Didn't run smooth until I give it some revs but I think that's down to plugs and leads etc.
But the main thing is the engine seamed sweet so will get stripped down and new gaskets etc
Now onwards to pull it out and get on with the resto
