convertible roof and radio not working after electrices died - 1992 Rivage
(In Topic #236116)
can anybody help?
As 90's with digifant have a ISV that is supposed to hum.
Check your fuses.
Sounds as if your new to you ignition switch isn't correctly installed bad, or that you may have broken a wire on the ignition switch cable, or a pin is wonky.
I have checked the fuses and they seem ok. I can see that people are talking about the cabriolet roof relay but I have not found that yet if you could point me in that direction?
We have gone back to the ignition switch and possible broken wires but not found anything. Not sure why the radio is not working either- would they be connected in some way?
I have never had electrical problems with my car, they don't seem as obvious to fix as the mechanics
The Top relays are in the boot behind the left side cardboard card.
What all did you remove to get the ignition switch removed?
Fuses all good and so are the relays in the boot.
There do not seem to be any broken wires in the ignition switch cable
I am going to take it to an electrics specialist later this week unless you can think of anything else I may have missed?
Bad primary grounds
water logged relay internals or fuse box from water migration from rust around the windscreen or Radio coax that didn't have a drip loop
Verify that you have good grounds. Frame to battery and Frame to engine.
If all you did was to change the ignition switch then it could be that the new switch is bad, if everything was working prior to the switch change.
