Car stalling
(In Topic #221687)
Car stalling
Sent from my SM-G930F using Tapatalk
Another thing you want to do it to do the residual pressure tests if you are losing pressure then this can cause the injectors to act wonky, it will eliminate the Fuel pressure regulator as a cause.
My buddy Ron has a great how to on static timing the Digi Cars with nothing but a DVOM.
Static Ignition Timing on VW A1 and A2 DigiFant Engines.
You basically place the car in time then look at your hall signal for going high to low.
If yours has a Catalytic Pervertor then you may have a wonky o2 sensor…
Now the Basics are that you have eliminated all vacuum leaks as unmetered air is a pain, and don't forget the idle by-pass screw as if you can turn it with your fingers then that is a air leak and you need a new o-ring…count the turns to remove it, write that down. Run to a good hardware store and get a new one, then also wrap the threads of the Screw and THREADS ONLY with telfon tape as that will prevent future air leaks.
Otherwise I would be suspect that your ISV could be causing issues but they are pricey, and you want to eliminate the easy ones first.
