Cambelt & timing marks
(In Topic #222503)
Move it one tooth?
fitted my new cam belt, and manually turned the engine over a few times after tensioning it - as standard.
Timing mark now looks to be maybe 1/2 to one tooth of depending on where you think the measure should be taken from.
This is how it currently looks:
Bottom pulley is at the correct position:
You can see from the first photo that if I moved it round then it would be pretty much in line with the top of the head casting - not the cam cover. Hyanes manual indicates it should it should be in line with the cam cover.
I guess that when the belt is tensioned it will rotate the cam sprocket counter-clockwise which is probably why it's moved.
What do we think? Move it forward one tooth, or leave it where it is…?
Last edit: by cedar
I'll have a mess with it and get it right. Easier to do it before I put the engine in.
J
