Cabby fuel filler neck
(In Topic #212041)
Fuel filler neck
Thanks,
Chubbsy
Tintop ones don't sit flush on the cap side.
I changed mine for a proper caby one after the previous owner had fitted a tintop one. I had to buy a longer bit of hose to join to the tank.
Alps 1992 Rivage Green, 1991 Rivage Blue (SOLD), 1986 GTI convertible White (SOLD)
I had no problems with the filler cap end fitting, it's no different to the original one fitted.
I did read you could bend the tintop one to fit but you can't as I tried that 1st.
Cabriolet filler necks are availed but they are pricy compare to tin top ones, about 3 or 4 times the cost!
Have a look at my thread as I fitted a tin top filler neck last year. https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-mk1-golfs_2%2Fmy-daily-drive-1988-gti&kfs79=120
Buy a new rubber hose between the filler neck and tank as they go brittle over time and 2 new jubilee clips is also a good idea.
Plenty of protection on the new filler neck will make it last a lot longer.
Sent from my HTC 10 using Tapatalk
Sent from my iPad using Tapatalk
