B pillar outer trim
(In Topic #211025)
B pillar outer trim
1990 Golf GTI cabrio 1.8i. DX Engine
Removing the "B" Pillar seal is trickier as you have to take off the rear quarter panel. to get to the window rail.
If you are removing it to paint, then the seal removal is warranted. If you want to "Polish it a wee bit" then you can do that on the car.
Start with 1000 grit wet/dry and water, work up to 3000 grit….wet/dry, and then a plastic polish or clear coat polish.
They will become black mirrors.
Just be sure to mask off the paint at the bottom edge.
To:
Good advice as always mate, lets see if I get the same results.. 👍
