Assistance required in North wales
(In Topic #219913)
Sent from my VTR-L09 using Tapatalk
Taking pictures and labels on wires/connections helps a lot when refitting stuff.
I've loads of pictures from when I removed my engine etc I can send/share if no one near you or loads on here and google etc…
https://clubgti.com/forums/index.php?threads/fusebox-faq.219775/
as well as the a2resource.com
Electrical Systems
Occasionally I can remember things or book mark them . . Great info there thanks Rub.
Your idle control valve is also the wrong way up, undo the 2 nuts on top of the rubber bushes and flip it over, you may need to re route the rubber hoses.
I found the hardest thing getting the engine back in was working out the order and routes for the cables and hoses….
If you have a look at my project page towards bottom of page 1 you can see what I mean…
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-mk1-golfs_2%2Fmy-daily-drive-1988-gti
I'll have a look at my electrical connection in a bit.
Idle control valve
5th injector
I’m not sure where your other wires are on your engine so the next couple of pictures may not help??
Some sort of switch attached to the throttle body
Thermo time switch on front coolant flange which tells the 5th injector to fire.
Let me know if you need any other pictures….
