Am I missing something here ..?
(In Topic #223030)
Should there be something there to cover the hole….?
Chairman
1986 Cabriolet (long resto!)
Follow us on:
Follow us on:
36thCrazyFist said
Yeah they break often, you want one of these https://www.classic-vw.co.uk/020-gearbox-timing-plug-cover-020301132-4034-p.asp
Ah thanks mate. Really appreciate it. Do I just plug it in the the one with he wider circle goes around it?
Do I need this too….
https://www.classic-vw.co.uk/020-gearbox-timing-plug-020301129d-4032-p.asp
rubjonny said
no you dont need the green bit, thats still in there. if you're careful you can tease the large round retaining ring thingy over the bung.
I guess the existing one used to be green once upon a time in its lifetime….lol
Rub is correct that you can get the inner plug ring over the outer, did it about 3 times in 300K miles….
I think it was a 1 or 1 1/4 connector…
like this.
the models with a smaller flywheel have a white one instead, b it of trivia these are adaptors for special VW timing equipment which reads from the square castings on the flywheel. there are 2 colours of insert to make sure the tool is set at the correct height into the gearbox bellhousing for the different flywheel t0pyes
