1988 Clipper speakers
(In Topic #218136)
Does anyone know the sizes for the front speakers? I've measured the inside of the stock speaker grill/housing and its a 4x6, is this correct?
Also the rear speakers have been fitted with a 3.5" speaker. Can anyone recommend anything slighty bigger or a 3.5" but has a shallow magnet. The current ones are being hit by the window when its wound down
For the rears It is a Crapshooot on what you can do and how they are made. I think IIRC I found a nice set at Radioshack, but that was 12years ago.
You are going to hit the speaker when you roll the rear window down, and on the 91.5-93 They increased the rears to 4X6 with external speaker grilles that allowed you more room in the rear….. But then again the rear windows may hit.
To accommodate the window cranks they added and extender to them so the crank would clear the grille.
You can buy then in different lengths.
If you stay oem, then you will need to just measure them. The rears are gonna be hit with the window mech no matter what you do, but you take it with a grain of salt.
The rear window does not go all the way down, not sure what speakers or price you want to pay be lots of info on line for speakers and sizes of the magnets if you are sure the magnet is to big.
Front speakers I've got, lacking in bass but that's down to poor design and speaker placement but a amp and sub in the boot sorts that problem out…
https://www.ebay.co.uk/itm/Alpine-150W-2Way-4-x6-4x6-SXE-Car-Door-Shelf-Speakers-/371057192333?_trksid=p2349526.m4383.l4275.c10
My rear speakers are some Sony ones but I can't remember which ones….
The rears are currently 2 inches deep and no longer work, either due to faulty wiring or by being hit with the window. I did however find these which have a depth of 1.6 inches. They may not be powerful but without modifying the available space they should work?
http://www.caraudiodirect.co.uk/vibe-slick-4-v5-speakers
I've got the original Blaupunkt stereo, so the speakers are not really banging it out you know I've changed the original dub rears as well as the cones were split, dried out more like..
The matching 3.5" speakers are also much shallower than the current ones fitted. They stop the window from winding down by another half an inch, its not much but its been damaging the magnets and they dont work. The dodgy wiring also doesnt help!
