1.8t caddy cranking over but won't start
1.8t not running/fuel issue
Hi in need of more help I'm really confuse I got the engine cranking over but it won't start the fuel pump primes but The injectors will not fire so I scanned it and got the code p0230 fuel pump primary Circuit so had a look at the relay 167 so this is the bit I'm confused about so pin 30 Constant 12v live
Pin 85 I think is ecu but it got about 3v and
pin 86 is switch Live so
pin 85/86 I meant to switch the relay but it doesn't can not get any power to pin 87 but if I test it on the bench it  works fine  any idea  oh and pin 87 go to the air maf DE41E06D-474B-49ED-8AFD-BF3733057A96.jpeg blue/yellow wire  49087A15-56B8-415F-B50F-F7A4BC13CB45.jpeg 9FFD8F6B-A33C-4909-854A-31F6E3767775.jpeg
