1.8GTI Auxiliary Air Valve Adjustment
(In Topic #219443)
Can it be adjusted?
When the engine is cold it starts almost immediately without any throttle needed and ticks over at around 1000 rpm. If I rev the engine the revs drop to below 1000 but come back up and settle at 1000. After about a minute the revs start to drop to around 600- 700 rpm and if I rev it the engine nearly cuts out but then settles at 600-700 rpm.
When the engine is stone cold idling at 1000 rpm, if I squeeze the aav pipe the idle drops but doesn't stall. Once it starts to idle at the lower speeds, when I squeeze the aav pipe it makes no difference to the idle which is why I believe the aav to be faulty.
When the engine warms up it idles happily at 950 rpm.
Can the aav be adjusted to allow more air through for longer at cold temperatures? There is a screw with a lock nut on it but I can't turn it while it's bolted to the car. Or am I better off just replacing it?
Thanks.
By your description of the way your AAv is behaving I would say it was okay but it is possible that it is not the right one for the car, they all look the same but behave differently.
A small update:
I found a loose jubilee clip on one of the hoses on the AAV which I've now tightnened up. It seems to have improved the cold running quite a bit. I need to check the CO again but that's anther job for another day!
I'll post any updates.
