1.8 cabby distributor vacuum
(In Topic #216470)
Merchandise Manager
Merchandise Manager
The thing on the carb I don't know.
Merchandise Manager
Merchandise Manager
If you have any vacuum ports avail, you can run a new one, you will need hard lines, hardware stores work well for that as the lines to attach water lines to icemakers.
Depending on the year it was usually attached to an upshift light.
at the top of the vavle cover is an open vac line, and any vac loss will cause the car to act really weird. and you can connect the dizzy there if you run the line.
Briano, in the uk we dont have hardware stores that stock parts for icemakers, in fact we dont really have hardware stores, we have ice trays that you put in the freezer.
the valve is called a non return valve
https://www.ebay.co.uk/itm/NON-RETURN-VALVE-FOR-AUDI-A4-A6-A8-SEAT-EXEO-Skoda-VW-PASSAT-07C133529A-NEW/222841536298?fits=Car+Make%3AVW&hash=item33e263ff2a:g:LL4AAOSwBahU3crX
or this one is £460 cheaper
https://www.ebay.co.uk/itm/GENUINE-Non-return-Valve-VW-AUDI-Corrado-Golf-Jetta-Passat-Scirocco-191611933A/263061548139?epid=1321325091&hash=item3d3fb0ac6b:g:DFoAAOSwjC9Ze68i
Get some new Breu or Bosch HT leads, dissy cap and rotor arm, I change mine every 2 years/20,000 miles.
Some new rubber braided vacuum hose should also help as yours looks rather frayed.
Try VW for the non return valve, it should come as the complete pipe.
Another idea which may work is block up the broken bit and if you can take the cover off the other outlet and see if you can fit the hose onto that one?
The bit on the carb is the fuel shut off solenoid, mine also has a bent at the connection, it looks like you have a wire going to it?
Merchandise Manager
Yes there is a wire connected to the bit on my carb. It's not bent tho it's completly broken off.
Merchandise Manager
Set of HT I use and recommend.
https://www.ebay.co.uk/itm/VW-GOLF-Mk1-1-8-HT-Leads-Ignition-Cables-Set-84-to-93-Bosch-803998031-VOLKSWAGEN/232464544425?fits=Model%3AGolf&epid=1949112671&hash=item361ff772a9:g:UvQAAOSw~l1Z7rUs
These will fit if you have the dissy cap with the pin style connection for the HT leads.
if your non-return valve nipples are all bust you can block them up with screws and sealant and instead put a T piece on the vacuum connection round the back of the carb. this nipple is for the warm air flap in the airbox in case you were wondering.
Merchandise Manager
